Inter switch trunking
Mar 29th, 2007
Got 2 switches connected together as follows
port f0/26 on a cisco WS-C2950C-24 to port g0/48 on a cisco WS-C2960G-48TC-L
They are auto sensing speed and duplex and I cannot find a command to tie them down.
The problem is that WS-C2950C-24 is auto sensing the duplex as full and WS-C2960G-48TC-L is auto sensing the duplex as half
I have coppied the show ver, show int and the interface config from both switches in a notepad attachment
I hope someone can help me with this
Overall Rating: 5 (1 ratings)
Amit Singh Thu, 03/29/2007 - 03:23
  • Cisco Employee,
Chris,
Can you please let us know the GBIC module you are using on 2960G Switch. Your 2950 switch port is 100 base FX and I think you also have a GBIC on 2960G as well.
-amit singh
Amit Singh Mon, 04/02/2007 - 03:38
  • Cisco Employee,
Hello Chris,
It looks like the SFP on 2960 port doesnot support "auto-negotiation" and falling back on half-duplex. Please try configuring the duplex as full under the SFP interface configuration.
Config t
Switch(config)#Interface ge x/y
Switch(config-if)#media-type sfp
Switch(config-if)#duplex full
http://www.cisco.com/en/US/products/ps6406/products_configuration_guide_chapter09186a0080511fcc.html#wp1080632
This should take care of the problem.
HTH,Please rate if it does.
-amit singh
