03-29-2007 02:25 AM - edited 03-05-2019 03:10 PM
Can anyone recommend a LAN card that can access multiple vlan through VTP at once. I have a cisco 2950 that has multiple Vlans and a VTP port i also have a server, i want all vlans to connect to the server. Can anyone Recommend a LAN Card. Thanks
Solved! Go to Solution.
03-29-2007 02:43 AM
Hi Friend,
VTP is a cisco propritory protocol so no LAN card will work for that and VLANs are not required to be propogated to servers.
I believe your requirement is to configure a port as a trunk port so that your server can access all vlans. If yes then you need to check with LAN card vendor to provide you a card which support and understand dot1q tag.
Ankur
03-29-2007 02:43 AM
Hi Friend,
Ankur
03-29-2007 03:45 AM
You need a LAN card with 802.1q support over it to trunk to the switch. You will not get VTP feature on the NIC as it is proprietry to Cisco.
-amit singh
