ACL Manager - problem with 2811 router
Mar 29th, 2007
I use ACL Manager (v.1.5 & 1.5). A want to edit access lists on 2811 cisco routers but this device has status unsupported. I have read that ACL Manager has reached end-of-sale or end-of-life status and may no longer be supported. What I can do to use ACL manager to edit access lists on 2811? or Which product repleace ACL manager?
Thx. KaM
David Stanford Thu, 03/29/2007 - 08:41
  • Cisco Employee,
You are correct that the 2811 is not supported by ACLM and it is EOL/EOS.
In LMS 2.6 you could use something like netconfig/config editor to edit the acl's of routers.
kmachalinski Fri, 03/30/2007 - 14:59
Thx for Your answer. I know netconfig and config editor but this applications are not so good for editing access list as ACL manager. I have many routers and must often edititng individual access list. I need applications like ACL manager. If Cisco has such new application?
BR KaM
