ACL question
Answered Question
Mar 29th, 2007
Hello.
I have below case:
interface FastEthernet0/0
description INTRANET
ip address 10.20.28.1 255.255.252.0
ip nat inside
duplex auto
speed auto
interface Serial0/0.3 point-to-point
dexcription INTERNET
ip address <real_ip> 255.255.255.192
ip nat outside
frame-relay interface-dlci 404
interface FastEthernet0/1
description DMZ
ip address real 255.255.255.192
duplex auto
speed auto
I want:
to allow only telnet from INTERNET to DMZ.
to allow ALL traffic from DMZ and INTRANET to INTERNET.
Pleas, help me with ACL rules...
Correct Answer by jitesh1982 about 9 years 9 months ago
Hello Max,
After such a long work I would like to know have your problem resolved, or uptill were you r to mark, so that I can try to help it out.
Rgds,
Jitesh
Overall Rating: 3.3 (5 ratings)
flashsplash Thu, 03/29/2007 - 05:31
i think (i just a started with my ccna)
access-list 101 permit tcp 0.0.0.0 255.255.255.255 your.?.ser.ver 0.0.0.0 eq 23
RouterA(config)#ip nat inside source list 1 interface [interface to the internet] overload
RouterA(config)#access-list 1 permit any
NetMaxKar Thu, 03/29/2007 - 05:36
but on which interface inbound or outbound should i need to apply this...
Amit Singh Thu, 03/29/2007 - 05:43
You can use an EXTENDED ACL to permit only the telnet traffic and attach it to the outbound direction on the serial interface.
config t
access-list 101 permit tcp eq 23
inet s 0/0.3
ip access-group 101 in
This should help you.
-amit singh
Jon Marshall Thu, 03/29/2007 - 05:59
Hi Amit
This might create some problems. If you apply this inbound on the serial interface you have in fact denied all other traffic other than telnet to the DMZ. This is probably not what is intended.
What might be a better solution is to apply your access-list on the DMZ interface in an outbound direction which would not interfere with the main traffic flow.
That is why i asked whether the poster wanted the intranet clients to be able to talk to the DMZ servers.
Jon
Jon Marshall Thu, 03/29/2007 - 06:08
I wasn't speculating on what he wanted and the answer given was not a solution to his problem.
The second part of the problem states that he wants to allow all traffic from the DMZ and the intranet out to the internet.
Now if you apply the access-list given on the serial interface in an inbound direction that would block ANY return traffic from the internet. The access-list is not stateful.
Jon
Jon Marshall Thu, 03/29/2007 - 06:20
The post is not about Amit's requirements. Amit and yourself supplied an answer that did not meet the requirements of the original poster. There is some confusion over Amit's answer in that he talks about applying the acl outbound but the config shows it being applied inbound.
I have posted incorrect or misleading posts before and am the first to accept if i have made a mistake. The issue is really to make sure the user doesn't do something that breaks his network.
So i still can't see how it is speculation. The requirements are quite plain.
Jon
Jon Marshall Thu, 03/29/2007 - 06:30
And i just got out of a very long boring and most importantly non-technical meeting so i wasn't in the best frame of mind.
Apologies if i came on a bit strong. No offense intended.
Jon
Jon Marshall Thu, 03/29/2007 - 05:46
Do you want to allow anybody from your intranet to access the DMZ servers or do you just want people on the internet to have access to DMZ with telnet ?
This makes a difference in the access-list
Jon
NetMaxKar Thu, 03/29/2007 - 06:23
Thanks everyone. Let me clarify.
Telnet was just example. In fact I need that:
1) ALL traffic from INTRANET to DMZ and INTERNET
2) ALL traffic from DMZ to INTERNET
3) SNMP and SNMPTRAPS from DMZ to INTRANET
4) ECHO, FTP, SSH, SMTP, DNS, TFTP, HTTP, POP3, NNTP, NTP, SNMP, SNMPTRAPS, HTTPS, SECURE POP3 from INTERNET to DMZ
and i want to use the next ACL (correct me if I wrong):
interface serial 0/0.3
ip access-group 120 in
access-list 120 permit tcp any any eq echo
access-list 120 permit udp any any eq echo
access-list 120 permit tcp any any eq ftp
access-list 120 permit tcp any any eq ftp-data established
access-list 120 permit tcp any any eq 22
access-list 120 permit tcp any any eq smtp
access-list 120 permit tcp any any eq domain
access-list 120 permit udp any any eq domain
access-list 120 permit udp any any eq tftp
access-list 120 permit tcp any any eq www
access-list 120 permit tcp any any eq pop3
access-list 120 permit tcp any any eq nntp
access-list 120 permit tcp any any eq 123
access-list 120 permit udp any any eq snmp
access-list 120 permit udp any any eq snmptrap
access-list 120 permit udp any any eq ntp
access-list 120 permit tcp any any eq 443
access-list 120 permit tcp any any eq 995
access-list 120 permit tcp any any eq telnet
Jon Marshall Thu, 03/29/2007 - 07:15
To control DMZ to intranet traffic use this access-list
access-list 101 permit udp "DMZ Subnet" 0.0.0.63 10.20.28.0 0.0.3.255 eq snmp
access-list 101 permit udp "DMZ Subnet" 0.0.0.63 10.20.28.0 0.0.3.255 eq snmptrap
access-list 101 permit deny ip "DMZ Subnet" 0.0.0.63 10.20.28.0 0.0.3.255
access-list 101 permit ip "DMZ Subnet" 0.0.0.63 any
apply it on the DMZ interface in an inbound direction.
interface fa0/1
To allow the other traffic use an acl for the serial interface and apply it in an inbound direction.
What you need to do is this
access-list 102 permit tcp any "DMZ Subnet" 0.0.0.63 eq ssh
access-list 102 permit tcp any "DMZ Subnet" 0.0.0.63 eq smtp
etc... add lines for all the traffic from the Internet to your DMZ servers.
access-list 102 deny ip any "DMZ Subnet" 0.0.0.63 # deny any other traffic to the DMZ servers
access-list 102 permit ip any any # allow all other return traffic
interface s0/0.3
ip access-group 102 in
the only other issue is echo. if you really want to allow ping from any internet machine to your DMZ servers
it is not
it is
access-list 102 permit icmp any "DMZ Subnet" 0.0.0.63 echo
This is not a particularly good thing to do. It allows people on the Internet to work out which machines you
have on public addressing.
Last point. The access-list 102 allows ftp, ssh etc. to all the servers in the DMZ. Presumably you don't have all
services running on all servers ie. say smtp was running on only one server. instead of
a more secure access-list would be
access-list 102 permit tcp any host "SMTP Server ip address" eq smtp
Jon
Jon Marshall Thu, 03/29/2007 - 07:39
One slight change to the above. if you want any traffic to be allowed from the DMZ to the Internet but only the specified ports from the internet to the DMZ
In our access-list 102 BEFORE the line
access-list 102 deny ip any DMZ Subnet" 0.0.0.63
you need the line
access-list 102 permit tcp any "DMZ Subnet" 0.0.0.63 established
This will allow the DMZ to initiate tcp connections to the Internet.
There is still a problem with non-tcp traffic initiated from the DMZ to the internet.
If there are any other connections that are initiated from the DMZ to the Internet you will need to account for the return traffic in your acl on the outside interface before you deny ip to the DMZ subnet.
The same applies to the intranet to the DMZ traffic.
You need to add to access-list 101 before the line
access-list 101 permit tcp "DMZ Subnet" 0.0.0.63 10.20.28.0 0.0.3.255 established.
This is why firewalls are quite useful - they are stateful so you don't need to account for return traffic in the same way !.
Jon
NetMaxKar Thu, 03/29/2007 - 11:33
access-list 101 permit deny ip ...
What does it mean permit deny?
Jon Marshall Thu, 03/29/2007 - 12:04
Sorry, that would be a typo.
It's meant to be "access-list deny ip...."
Jon
Correct Answer
jitesh1982 Fri, 03/30/2007 - 02:59
Hello Max,
Rgds,
Jitesh
