How can I allow the vsan 1 trunking
Answered Question
Dear All,
I'm worrying about the vsan 1 isolation during enabling ISL link.
Each switch has vsan 1 configuration, and I will do following prcedures:
1. suspend one of vsan 1
2. enable ISL link
Will this situation cause vsan isolatoin?
Or
It will establish the 2 switched in a fabric?
Thanks for any prompt,
Dennis
Correct Answer by stephen2615 about 10 years 19 hours ago
I had a bit of unnecessary grief with this also. It looks wierd because I had no zoneset in VSAN0001 and it is best practice not to use VSAN0001 for production.
I used VSAN0001 to link all our switches into one fabric so I had a single management VSAN. Every time I added a new switch, VSAN0001 had a fit for a few moments but as long as I had one port in the VSAN enabled, it all came good.
The important thing that I learnt was to make sure the principal switch would remain the principal switch and the Domain IDs for each VSAN (including 0001) were unique. I found that one of my new switches had the same Domain ID as my principal switches VSAN0001 Domian ID. Once I fixed that, everything went ok.
As VSAN0001 did not have any production data in it, nothing bothered the production VSAN's.
Clear as mud eh?
Stephen
Overall Rating: 5 (2 ratings)
Correct Answer
stephen2615 Fri, 03/30/2007 - 02:13
  • Bronze, 100 points or more
Clear as mud eh?
Stephen
Trending Topics: Storage Networking
