How can I enable IVR on FCIP environement
dennis.dai
Dear All,
I will do following procedures to enable IVR on FCIP environment.
1. 'show wwn switch' command to record both of local and remote Switches' WWN.
2. set unique domain ID required if SAN-OS less than Release 2.1.
a. fcdomain domain domain_number static vasn vasn_number
b. config t; vsan database; vsan vsan_number suspend; no vsan suspend; end
3. enable
a. config t
b. ivr enable
4. config IVR-enable border switches.
a. ivr vsan-topology database
b. autonomous-fabric-id 1 switch-wwn 20:00:00:0d:ec:09:8d:00 vsan-ranges 10,99
c. autonomous-fabric-id 1 swtich-wwn 20:00:00:0d:ec:0c:e6:40 vsan-ranges 20,99
5. Zoning
a. ivr zone name IVRZone1
b. member pwwn PSPA3 (vsan ?)
c. member pwwn PSPB3
d. exit
e. ivr zoneset name IVRZoneSet1
f. member IVRZone1
g. exit
h. ivr zoneset activate name IVRZoneSet1 force
6. Verify
a. exit
b. show ivr vsan-topology
c. show ivr zoneset active
e. show ivr
Could you advice me the above prcedures need to run only one switch or need to run both of swtiches?
Thank you,
Dennis
