Revision & VTP
Answered Question
Hello Experts!
I'm Afraid from the Revision Numbere of the VTP Domain:
I have the following Scenario:
i have CORE Switch;the VTP Domain Info is:
CORE
VTP Domain XYZ
VTP MODE SERVER
Now i want to install new Distribution;Distribution VTP info Must be:
DS1
VTP Domain AAA
VTP Mode Server
but i need DS1 To learn about all vlan's already created onto the core.
what am think to do is:
First instal DS1 As:
vtp domain XYZ
VTP Mode client
in this action the new DS1 Learned all vlans on the core
than:
change the DS1 VTP Domain to AAA
DS1
VTP Domain AAA
VTP Mode server
1)is this a good thought?
2)is this thought avoid the Problem of the High revision?
ur suggestion its very much appreciated
regards
ALI
Correct Answer by Amit Singh about 9 years 10 months ago
Hi Ali,
1. Yes you are right, i meant that change it to some bogus name and then change it back to XYZ and then check the revision number on the switch before connecting it to the Core switch.
2.Changing the switch to client mode and back to server mode doesnot reset the revision number. It only gets reset by changing it to transparent mode and back to server.
You can use either of the above mentioned step.
-amit singh
Correct Answer by ankbhasi about 9 years 10 months ago
Hi Ali,
As per me you should change the VTP mode to transparent and then back to server and then again confirm the config revision number before adding this switch into the network.
This will make your config revision number 0 on DS1 switch.
Once you are sure config is back to 0 on your new switch then place that switch into the network with same domain name and it will get all vlan information from your core switch which has higher revision number.
Ankur
Ali,
Why do you want to have diffrent VTP domains at Core and Distribution. It should be same across the network if you are running the same vlans.
My thougths on this:
1. Before connecting the DS1 switch to core switch, change the VTP domain name to some bogus name and then change it to XYZ. This will reset the revision number to zero. You can also change the VTP mode to transparent and then back to server.
2. As I said in the point 1, do this before you connect the switch to the core switch.
HTH,
-amit singh
Overall Rating: 5 (3 ratings)
Correct Answer
Amit Singh Thu, 03/29/2007 - 05:29
Ali,
HTH,
-amit singh
Correct Answer
Amit Singh Thu, 03/29/2007 - 05:48
Hi Ali,
-amit singh
Correct Answer
ankbhasi Thu, 03/29/2007 - 05:39
Hi Ali,
Ankur
Amit Singh Thu, 03/29/2007 - 06:02
No issues buddy, we will be help you with all these products. You are always welcome on this forum with your queries.
-amit singh
