Webview failed after installing ISE
stevele71
After installing ISE, successfully login to Webview but can only see the frame and no menu to select report type. Any thoughts?
ICM 6.0 SR7
Tried uninstalling SR7, rerun ICM setup from media and bin but still having the same issue.
bullett
Pretty sure this is permissions based.
Case sensitive logins. You can login using the 'wrong' case when going into wv you just won't be able to run reports until you use the right case.
Have you also checked Jaguar is running? it was always a bit wobbly on v6.
Cheers
Bully
