joquesada Thu, 03/29/2007 - 06:08
  • Bronze, 100 points or more
Hi Frederik,
According to documentation, you indeed can configure a flow timeout for UDP flows: http://www.cisco.com/univercd/cc/td/doc/product/webscale/css/css_740/cmdrefgd/cmdowcnt.htm#wp1140473
Normally the CSS doesn't keeps track of UDP flows, with the exception of DNS ( UDP 53 ) and SIP ( UDP 5060 ), so you shouldn't have a problem using the flow timeout multiplier command for UDP port 53.
Reference: http://www.cisco.com/univercd/cc/td/doc/product/webscale/css/css_740/cmdrefgd/cmdgloba.htm#wp1409551
Thanks!
Jose Quesada.
