E1 Controller
Answered Question
Mar 29th, 2007
Two questions:
If i use an E1 G703 for a lease line at 256k. I need to configure 2 or 4 Timesolts?
I think 4 but my ISP tell me 2.
Who is right?
I think: E1 -> 2048 with sync (32ts).
1 ts = 64k. 2ts= 128k 4ts=256 !
Second question. All G703 use NSA frame?
Thank for your answer
Correct Answer by Amit Singh about 9 years 11 months ago
You need 4 tile slots for sure.
NSA frame ???
-amit singh
Overall Rating: 4 (3 ratings)
Correct Answer
Amit Singh Thu, 03/29/2007 - 06:16
NSA frame ???
-amit singh
royalblues Thu, 03/29/2007 - 06:19
You would need to configure 4 timeslots
Each timeslot will give you 64K and hence you would require 4 timeslots
Controller e1 0/0
channel-group 0 timeslots 1-4
I didn't clearly understood your 2nd question
HTH, rate if it does
Narayan
fargier Thu, 03/29/2007 - 06:31
For the second question, I think like you !! Provider send me to configure frame NSA + CRC4.
Crc4 is not a problem i can configure that. But for the NSA, i never see that. What is it? Convertion for N= ? S= ? A= ?
But thank for all your answer
Paolo Bevilacqua Thu, 03/29/2007 - 06:33
NSA (Non Service Affecting) is a minor alarm frame that can be sent by T1/E1. I don't think the router uses it and I've never seen it used in practice.
