NAT incoming vpn's
Mar 29th, 2007
i am running into problems trying to NAT incoming vpn connections. here are all the outputs that i think would show the problem. if you need more please ask
access-list vpn_nat extended permit ip log
nat (Outside) 1 access-list vpn_nat
but I do not see the hit count increasing on the nat
NAT policies on Interface Outside:
match ip Outside Outside
dynamic translation to pool 1 ( [Interface PAT])
translate_hits = 0, untranslate_hits = 0
DCP-ASA5520-2# sh vpn-sessiondb remote
Session Type: Remote
Username : remote
Index : 1
Assigned IP : Public IP : 12.xx.xx.xx
Protocol : IPSec Encryption : 3DES
Hashing : MD5
Bytes Tx : 0 Bytes Rx : 3297
Client Type : IOS Client Ver : 12.4(4)T2
Group Policy : remote_sites
Tunnel Group : remote_sites
Login Time : 06:31:29 UTC Thu Mar 29 2007
Duration : 0h:10m:31s
Filter Name :
NAC Result : Unknown
Posture Token:
Here are my pools for the incoming vpn's
ip local pool NAT_VPN_Routers mask
tunnel-group remote_sites general-attributes
address-pool NAT_VPN_Routers
bstremp Wed, 04/04/2007 - 06:15
Posture Token?Informational text string configurable on the Access Control Server. The ACS downloads the posture token to the security appliance for informational purposes to aid in system monitoring, reporting, debugging, and logging. A typical posture token is Healthy, Checkup, Quarantine, Infected, or Unknown.
