ISDN problem
Mar 29th, 2007
1#
004523: Mar 29 15:40:45.353 SAST: ISDN BR0 SERROR: isdn_get_guid: Cannot allocate a GUID (5)
004524: Mar 29 15:40:45.353 SAST: ISDN BR0 SERROR: isdn_get_display_text_from_gtd: false ret
004525: Mar 29 15:40:45.353 SAST: ISDN BR0 SERROR: isdn_get_mlpp_from_gtd: MLPP from GTD failed
004526: Mar 29 15:40:45.357 SAST: ISDN BR0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Calling num 6750
004527: Mar 29 15:40:45.361 SAST: ISDN BR0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Called num XXXXXXXXXX
004528: Mar 29 15:40:45.381 SAST: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0, TEI 64 changed to up
004529: Mar 29 15:40:45.385 SAST: ISDN BR0 Q931: TX -> SETUP pd = 8 callref = 0x4D
Bearer Capability i = 0x8890
Standard = CCITT
Transfer Capability = Unrestricted Digital
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x81
Calling Party Number i = 0x0080, '6750'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, 'XXXXXXXXXX'
004530: Mar 29 15:40:45.549 SAST: ISDN BR0 Q931: RX <- SETUP_ACK pd = 8 callref = 0xCD
Channel ID i = 0x89
Progress Ind i = 0x8188 - In-band info or appropriate now available
004531: Mar 29 15:40:45.605 SAST: ISDN BR0 Q931: RX <- DISCONNECT pd = 8 callref = 0xCD
Cause i = 0x818380 - No route to destination
004532: Mar 29 15:40:45.617 SAST: ISDN BR0 Q931: TX -> RELEASE pd = 8 callref = 0x4D
Cause i = 0x8083 - No route to destination
004533: Mar 29 15:40:45.665 SAST: ISDN BR0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xCD
Cause i = 0x8190 - Normal call clearing
004534: Mar 29 15:40:47.561 SAST: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0, TEI 64 changed to down
004535: Mar 29 15:40:47.561 SAST: ISDN BR0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
what is causing this? The other thing is that our router is making connections out to this router and its not accepting it......
owaisberg Thu, 03/29/2007 - 07:08
Please post your configs from both routers
Thx,
OW
bradlesliect Thu, 03/29/2007 - 07:22
My Router:
interface Dialer20
description isdn backup
ip address 192.168.225.237 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
no ip split-horizon
shutdown
dialer pool 1
dialer remote-name cr1.client.router
dialer idle-timeout 180
dialer string XXXXXXXXXX
dialer-group 2
no cdp enable
ppp authentication pap
ppp pap sent-username cr1 password
ppp multilink bap
ppp multilink links maximum 2
ppp multilink load-threshold 128 either
end
username cr1. password
Client Router:
interface BRI0
description number
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
dialer pool-member 1
isdn switch-type basic-net3
isdn point-to-point-setup
isdn calling-number 6750
fair-queue
ppp authentication chap pap
ppp multilink
end
interface Dialer0
description my router isdn number
ip address 192.168.225.238 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
no ip split-horizon
dialer pool 1
dialer-group 1
fair-queue
no cdp enable
ppp authentication pap callin
ppp chap refuse
ppp pap sent-username cr1. password 7 removed
ppp multilink bap
ppp multilink links minimum 2
ppp multilink endpoint string client-backup
end
hostname client.router-cr1
owaisberg Thu, 03/29/2007 - 07:38
Please run this command and see if you connect:
isdn test call interface dialer#
And your Dialer20 is in shutdown state, make sure you remove it of course.
Thx,
OW
bradlesliect Thu, 03/29/2007 - 23:41
these results are from a test call.
i did debug isdn error and debu isdn q931
owaisberg Fri, 03/30/2007 - 06:59
can you please send me your
"show isdn status" from both routers
Thx,
OW
paolo bevilacqua Thu, 03/29/2007 - 09:42
  • Hall of Fame,
    Founding Member
Che with your telco why they are not delivering the call and return such a strange error given - no route to destination !!!
owaisberg Fri, 03/30/2007 - 07:19
Brad,
One more thing.....couple more questions:
what is the purpose of using
isdn point-to-point-setup and isdn calling number in your setup ?
In cisco documentation it says isdn calling number used to configure australian basic-ts013 switch but your current switch is
basic-net3
Please clarify.
OW
paolo bevilacqua Fri, 03/30/2007 - 11:07
  • Hall of Fame,
    Founding Member
Hi OW,
In the documentation, the reference to australia switches is obsolete and out of context.
These commands can be used with any switch type and their purpose is:
isdn point-to-point-setup: sends the setups messages to 'unicast' TEI only. No need to change that - alternative would be send point-to-multipoint, that is to broadcast TEi 127.
isdn calling number: auto-explicative.
Hope this helps, if so please rate post!
