WCS server
MICHAEL SCHROEDER Fri, 03/30/2007 - 00:59
Hi Eduardo, i recommend you to run WCS as Service on a dedicated Server, without any other Application (Ok, Adobe Reader should not a be Problem), especially other Netweork Management Products. WCS uses some TCP/UDP Ports for Communication, like SNMP, FTP, TFTP, Syslog, https and so on, so you have to keep these ports available. Regards, Michael
PS: in a Lab Environment i have a WCS Server and a VMWare with Cisco ACS on the same Machine, runs perfectly.
sbarasiscom Wed, 06/20/2007 - 04:59
Dear Michael ,
Can you tell me what is the RAM in the machine which you use it for (ACS and WCS) and what about CPU ?
MICHAEL SCHROEDER Thu, 06/21/2007 - 01:51
Hi, the Machine is a HP DL140 Server with 2GB RAM and 3GHz Processor. Be aware, this is not officially supported and for Lab uses only.
Regards, Michael
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
