console lockout on CSS
Mar 29th, 2007
Hello
I am using a CSS11503 with a reflection client accessing the console port. I hit ctrl shift s to clear a screen lock problem and the console has stopped responding. The device is still up. Anyone come across this before?
Donagh
Syed Iftekhar Ahmed Thu, 03/29/2007 - 09:51
please press CTRL-Q to send an XON
to the CSS. If the cause of the hang was XOFF character then CTRL-Q would fix
it.
Syed
donaghq_2 Thu, 03/29/2007 - 10:57
Thanks for that Syed but it did not work. It is definitely something like you say as Ctrl Q was the other sequence I entered to get out of the screen lock problem in reflection. It would be good to be able to disable the console from interpreting these commands. Do you know how?
I have rebooted the box since and the device is working.
Donagh
