using KRON with interactive command? <Squeeze>
Mar 29th, 2007
I need to schedule a automated periodic squeeze of a filesystem <don't ask... long story> on a 4500 switch running 12.2(31)SGA code. Problem is, the squeeze command has an interactive "...Continue?" prompt, which requires a simple <CR> to proceed. The KRON facility doesn't seem to like any keyboard-interactive commands like this.
I checked the listed operators on the squeeze command, there does not *appear* to be a way to supress the prompt.
Since this is a 45k with 12.2 based code, there's no rescue using a TCL script. :(
So... Question is, can anyone think of a creative way around this 'problem'? Is there a way to pass the carrige return needed to execute the squeeze operation on the same kron cli command line somehow?
Any suggestions would be greatly appreciated!
Edison Ortiz Thu, 03/29/2007 - 19:33
I haven't tried myself but just a suggestion, how about using macro along with kron ?
reachonenetadm Thu, 06/21/2007 - 09:16
my impression is that kron does not allow any command which requires user input, not even simple confirmation. Unless the copy command (or in my case the clear counters command) provides a switch to skip user prompts, then kron is not a viable solution.
