Unity Partition User Directory for Forwarding Messages
Mar 29th, 2007
Is there any way to partition the Users in the Directory for forwarding purposes? For example, if i press "5" after listening to a message, the prompt says "Please enter the first few letters of the last name, then press pound"
This will query all users, so I could potentially forward messages to another company (hosted platform)
Is there any way to get around this? We have 4.0.5 . Thanks
lindborg Thu, 03/29/2007 - 14:34
  • Cisco Employee,
Unity 4.2(1) and later supports this - you can restrict the address list on a per subscriber baisis (assigned to groups using BulkEdit if you like). This includes addressing new messages and forwarding messages.
mdury Thu, 04/19/2007 - 11:25
Jeff,
Do you have any hints on how to implement this feature as well?
THanks
lindborg Mon, 04/23/2007 - 07:26
  • Cisco Employee,
Hmmm... just went back and looked - the ability to limit the address book on a per user basis (as opposed to editing the primary location objects's search scope system wide) did not go out with 4.2(1) - it's in the 5.0(1) systems we're testing now.
I believe the FCS for 5.0 is the end of May at this point.
mdury Mon, 04/23/2007 - 07:39
Is there any other workaround for 4.2.1 ?
jsailers Fri, 03/30/2007 - 16:18
Starting in 4.0, you can create a directory handler that uses CoS, Distribution List, location (and many more) to narrow down the list of users that appear in the directory.
We use Distribution Lists mainly, but as I said, there are many options to choose from.
