BARS data (when replacing publisher server)
Answered Question
Mar 29th, 2007
Hi there,
I gonna replace the publisher server and then connect the new publisher with the existing subscriber.
My question is:
When I run BARS and choose the data source server, should I choos both publisher and subscriber server?
Or just publisher server?
I read the BARS document as follows,
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00807a78ce.html
And "Replacing Servers During the Upgrade" as follows, http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/4_1/install/upgrade/upg413/replace.htm
Those documents don't include the detailed information.
Thanks.
Correct Answer by rob.huffman about 9 years 9 months ago
Hi Qinghao, Thanks man!
Good stuff, you are halfway there! The db replication problem and DC directory health problem are most likely related;
Interpreting the Results
The validation results display in the Upgrade Assistant Summary window. At the top of the window, a report summarizes the results for all modules and displays which modules failed, which modules produced warnings, and which modules passed. A link to the folder that contains all log files, including the Upgrade Assistant Summary report, displays also.
To identify a problem with the failed validation module, review the following information that displays in the Summary window:
The first link points to the log file that specifies the error or warning.
Click the first link and search for the error or warning; for example, ERR: or WARN: .
The second link points to the corrective action file that describes the log file error message and recommends the corrective action.
Click the second link to open the corrective action file. Search the corrective action file for the error message that is noted in the log file. Review the description and corrective action.
Caution After you correct all problems that the utility identifies, Cisco strongly recommends that you run the utility again on every server in the cluster before you begin the upgrade.
Obtaining the Log File
You can obtain the results from the utility in the following directory:
C:\Program Files\Common Files\Cisco\Logs\UPGRADEASST (for example, UPGRADEASST-05-15-2003_13.47.58)
To access the log file, click the Summary file.
Tip A link to the log file displays in the Summary window for every failed validation module. To access the log file, click the link in the Summary window.
The Summary.html file, which is the Upgrade Assistant Summary report, provides the exact same information that displays in the Upgrade Assistant Summary window.
Each time that you run the utility, the utility creates a new log folder and new set of log files. The utility does not remove the log files, even if you uninstall the utility. You erase the log files when you reimage the server or manually delete the files.
From this good doc;
Using Cisco CallManager Upgrade Assistant Utility 4.1(3) for Cisco CallManager Release 3.3(5) and Later Releases
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_installation_guide09186a00803f5c59.html#wp262763
**This db replication between Pub and Sub(s) is broken**
The publisher database server upgrade requires that all call-processing processes that the server handles fail over to the configured subscriber servers. Database replication must exist prior to the upgrade, so failover occurs.
This utility verifies the database replication status for all subscriber servers in the cluster. This utility validates that the database contains the latest information about the system. Validation results include Running, Idle, Failed, or Succeeded.
Have a look at this doc for the method to fix the db replication issue;
Using DBLHelper to Reestablish a Broken Cisco CallManager Cluster SQL Subscription
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801e7ddf.shtml
Hope this helps!
Rob
Hi Qinghao,
You can identify the Sub as a backup target but its not a must unless you have different files in the TFTP folder that are not in the Publisher database. The Backup Target designation is usually for CRA,CER Servers etc. So 9 times out of 10 just the Publisher!
**For subscriber databases that are configured for backup, BARS backs up only TFTP files and CDR/CMR files.**
The following list shows the data that is backed up and restored for the Cisco CallManager publisher database:
Hosts and LMhosts files
Latest Cisco CallManager publisher database
DC Directory LDAP directory
For Cisco CallManager 3.3.x DirectoryConfiguration.ini from C:\dcdsrvr.
For Cisco CallManager 4.0(x) or later UMDirectoryConfiguration.ini.
Directory schema files avvid_schemaV*.txt
Publisher and subscriber configuration information to replication.ini file.
Cisco CallManager version to version.ini file.
If the option to backup CDR is chosen, CDR database and CDR/CMR flat files from Local CDR Path
TFTP files from C:\Program Files\Cisco\TFTPPath (the default path)
TFTP files from alternate file locations
Cisco Bulk Administration Tool (BAT) files-templates from C:\CiscoWebs\BAT, CSV files from C:\BAT and the BATversion.asp file.
HKLM\Software\Cisco Systems, Inc. (registry keys)
Cisco CallManager DSN
Security files (certificates) from under C:\Program Files\Cisco\Certificates. This applies only to Cisco CallManager 4.x or later.
LDAPConfig.ini for IPMA configuration.
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00805e6496.html#wp43860
Hope this helps!
Rob
Overall Rating: 5 (2 ratings)
Correct Answer
rob.huffman Thu, 03/29/2007 - 13:40
Hi Qinghao,
From this good doc;
Hope this helps!
Rob
master001 Thu, 03/29/2007 - 15:19
Hi Rob,
Thanks. You are very helpful.
Now the publisher server(CCM3.3(5)) has been replaced. The IP phone has been registered to it.
My next step is upgrading PUB and SUB server from 3.3(5) to 4.1.(3).
Now I run CCM upgrade assisstant, there are two issues:
1. PUB shows "database replication status validation failed"
2. SUB shows "DC Directory healthy status validation failed"
Do you have any idea? Thanks.
Correct Answer
rob.huffman Thu, 03/29/2007 - 16:52
From this good doc;
Hope this helps!
Rob
master001 Fri, 03/30/2007 - 15:59
Hi Rob,
You are a really expert. Not only your knowledge , but the way you coach is impressive.
The DBLHelper resolved the problem.
One more question:
Could you share your idea of collecting cisco documentation?
Since cisco documentation is all over the website, it takes time get the 'good' and right document that meets your needs.
Thanks again.
rob.huffman Fri, 03/30/2007 - 17:52
Hi Qinghao,
Thank you for your kind words :) I am not an expert by any means, but I am trying to learn day by day. There is much to learn! I have spent at least 1000 hours reading and studying documents on the Cisco site and you are correct that sometimes it is very hard to find what you are looking for.
Start by logging in, this gives you access to a greater wealth of available docs.
Think of keywords like CCM database or ccm db
Keep trying different combinations
When you find a great doc, save the link or better yet save the pdf in a file on your desktop. You may find a great link oneday and have trouble ever finding it again.
Don't give up! The information you are looking for is almost always lurking somewhere on the site.
Use the search function on the Forums, there really are some great experts who post answers on a daily basis.
Check out Cisco Press (link on this site) there are some superb books that cover a wide range of topics.
Keep on posting :)
Hope this helps! And best of luck on your journey!
Rob
rob.huffman Sat, 03/31/2007 - 07:37
Hi Qinghao,
You are correct here :) For migration info;
Try -
migrate > migration > upgrade > upgrading
See which one of these keywords comes up with the results you are looking for. You need to weed through the documents and add/subtract new keywords until you find what you need.
Because you are moving to CCM 4.1.3, I put in "troubleshooting 4.1.3"
This comes up with 571 results;
http://www.cisco.com/pcgi-bin/search/search.pl?searchPhrase=troubleshooting%204.1.3
Or put in "features 4.1.3"
This comes up with 621 results
http://www.cisco.com/pcgi-bin/search/search.pl?siteToSearch=cisco.com&searchPhrase=features++4.1.3&country=US&language=en&filter=p&search=Search
You can ping me @ [email protected]
So, keep searching, keep reading, keep posting and have fun :)
Rob
master001 Sun, 04/01/2007 - 18:05
Hi Rob,
You are the best guy I met on Netpro.
I appreciate your sharing.
Qinghao
