ASDM Upgrade
David White Thu, 03/29/2007 - 19:32
If you are indicating that authentication is failing, then you need to look at the output of
debug aaa authentication
debug radius
to see why. Also, "show aaa-server" may help as well.
mkkeyan Sun, 04/01/2007 - 00:57
http server enable
http inside
then check the PIX for asdm filename
ie Show flash
asdm image flash:/your file name
or you can rename the file according to the above line.
