Registering an IP Phone thru a WAN using CME
Answered Question
Correct Answer
Paolo Bevilacqua Thu, 03/29/2007 - 12:52
  • Hall of Fame,
    Founding Member
Sure. Under ephone, configure g729 and mtp.
k_vishwesh Sun, 04/01/2007 - 21:51
jose,
cisco design says not to configure any remote location phone using cme.
But yes techinically you can configure it.No CME phones supports locally g729 codec. so u cannot use it.This is the only reason why i feel cisco doesnt recommends to use phones across.
vishwesh
sandeep pokhriyal Sun, 04/01/2007 - 23:54
hi Vishwesh,
can u pls provide some link where cisco is not recommending registeration over the WAN.
we are seriously looking for this.
regards,
Paolo Bevilacqua Mon, 04/02/2007 - 03:11
  • Hall of Fame,
    Founding Member
K.Vishwesh is incorrect.
You can perfectly deploy remote phones with CCME and Cisco has never recommended against.
From CCME 4.1 Datasheet at:
http://cisco.com/en/US/products/sw/voicesw/ps4625/products_data_sheet0900aecd805e1a1f.html
Remote tele-worker IP phone support
Link to configuration guide for remote phones:
http://cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00807e13a7.html#wp1061320
Also stating that the phones do not support G.729 is oncorrect. To the contrary, all telephones do support it.
