3750G stack port problem
Mar 29th, 2007
Just received 4 3750G, connected the stack cables to the stacking ports, boot up and the POST shows that no cables are connected. Is there a configuration step that I missed?
LEACHMIKE Mon, 04/02/2007 - 13:56
During the POST sequence , I see a message that no cables are in the stack ports. I have 4 switches all cabled together and all 4 get the same errors. Is it possible that all 4, which were manufactured on the same day have defective stack ports, or that all cabeling is also bad.
I had assumed plug and play for this
glen.grant Mon, 04/02/2007 - 17:35
How are cables hooked up ? Should be port 1 to port 2 all the way down the stack and port 1 on bottom should go to port 2 on the top switch . Also make sure you power up one at a time with the chosen stackmaster first .
LEACHMIKE Tue, 04/03/2007 - 06:22
That is exactly the way it is cabled, and I power up one at a time, yet the ports show as empty
LEACHMIKE Wed, 04/04/2007 - 09:44
The stack ports were defective. New switches will be delivered. Thanks for the replies
