VPN Dial-in users get Fixed DHCP address
Fraser Reid
Hello
I use a 706VXR as a VPN gateway and my users use the Cisco VPN Client to gain access .
What I would like to do is have them always getting the Same IP Address every time they dial in .
ie. user fred will always be given 10.0.0.12 and user wilma will always be given 10.0.0.13.
can this be done ?
All I am using just now is a standard DHCP Pool .
Fraser
kaachary
On router, you can not achieve this. This functionality is available in Concentrator and ASA .
As a workaround, you can create two separate groups for two users, with two different pools of single ip address.
Hope this helps.
-Kanishka
