Cisco 851W and VLANS
Mar 30th, 2007
I have a Cisco 851W router and I'm having this configuration:
All LAN ports and dot11Radio are bridged.
So now I'm trying to do this thing:
I'm trying to create a wireless guest net .
So i've created a bridging vlan 1 native that is for my current trusted ssid and another routing vlan an ssid that is for my guest net .
The problem is that when i create vlan 1 it locks me out: i can connect to the wireless but i cant access nothing on the router (FastEthernet 0-4)
Any solutions ? Thanks
ebreniz Mon, 04/02/2007 - 12:06
Do you have any ACL(access-list) configured on your router?. Send your router configuration. Looking at that, I can understand the problem better.
rajinikanth Mon, 04/02/2007 - 22:54
How are you accessing to manage the router. via console or telnet.
Why u want to use vlan 1 native. by making vlan 1 native your trying to send vlan1 packets untagged across the link.
Try using only vlan 1 withous native command and check if it works.
calin.perebiceanu Mon, 04/02/2007 - 23:36
Thanks's for the response . I will try , but now
i've discovered another problem that may cause this one
Here is the link :
I will attach the running config , but i deleted any encrypted hashs and public ip's
(this is a public forum after all}
