Securing 3750
Answered Question
Mar 30th, 2007
If I configure HSRP in vlan interface, which is the best place to put the config below? Physical interface or vlan interface and why?
FYI, I put it in vlan interface because the routing information is there (i.e ip address and HSRP).
access-list 30 remark Multicast-filtering-ACL
access-list 30 deny 224.0.1.35 log
access-list 30 deny 224.0.1.60 log
access-list 30 deny 224.0.1.3 log
access-list 30 deny 224.0.1.2 log
access-list 30 deny 224.0.1.22 log
access-list 30 deny 224.0.1.24 log
access-list 30 deny 224.0.0.0 0.0.0.255 log
access-list 30 deny 239.0.0.0 0.255.255.255 log
access-list 30 permit 224.0.0.0 15.255.255.255 log
interface physical_or_vlan?
no ip redirects
no ip directed broadcast
no ip mask-reply
no ip unreachables
no ip proxy-arp
ip accounting access-violations
ip multicast boundary 30
no ip mroute-cache
ntp disable
no cdp enable
TIA
Correct Answer by Jon Marshall about 9 years 9 months ago
Hi Danilo
Not sure i fully understand. The layer 3 interface is the SVI so that is the logical place to put the layer 3 access-list that you have created.
When you say the physical interface which physical interface were you thinking of ?
If the physical interface was configured as a routed port then the access-list would go on there but this isn't what you have done.
Could you clarify ?
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Fri, 03/30/2007 - 00:27
Hi Danilo
Could you clarify ?
Jon
Danilo Dy Fri, 03/30/2007 - 00:39
Hi Jon,
Thanks for your reply.
I think you have answered my question. I just tried putting those config in the physical interface, it won't accept it if I don't put routing configuration on it.
