03-30-2007 12:27 AM - edited 03-05-2019 03:11 PM
I`m converting 2 Cat6506 with Sup2/MSFC2 from CatOS to IOS. The Sup2/MSFC2 has only DRAM:128MB and ONBOARD FLASH:32MB. Please I need locate the way to upgrade the DRAM from 128MB to 256MB or better to 512MB.
Thanks in advance
Solved! Go to Solution.
03-30-2007 02:30 AM
Hi Luis,
Have a look at this link which will help you in upgrading DRAM
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/cfgnotes/78_6953.htm
If you also want to upgrade the DRAM for sup engine then this link will help you
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/cfgnotes/78_12693.htm
Ankur
*Pls rate all helpfull post
03-30-2007 02:30 AM
Hi Luis,
Ankur
03-30-2007 07:03 AM
Hi Ankur,
Thanks a lot for your info. It was very useful to solve my problem.
Thanks again
