need to change reconfigure vpn connection due to new ip address
Mar 30th, 2007
My current situation is that i have 8 ASA site to stie vpn connected together. My company is changing isp providers and we wont' be using the same ip address anymore on two of the sites. I know i have to change the outside ip address on the ASA for the two sites but how do i configure the vpn with the new ip address? Do i need to configure ASA again from scratch and use the vpn wizard to connect all my sites? And if do have to configure from scratch how do i remove the old tunnel and ip address from the other ASA?
Overall Rating: 4 (1 ratings)
kaachary Sat, 03/31/2007 - 03:19
  • Cisco Employee,
To remove the configuration for an exisitng tunnel fro mCLI :
clear configure tunnel-group
clear configure crypto map
clear configure access-list
Yes, you have to configure ASA for new tunnels from scratch.
-Kanishka
