jbayuka Thu, 04/05/2007 - 10:19
First check if you have assigned an ip addresss under the user setup | client ip address assignment | specify the static ip address. Also go into Configuration | System | Address Management | Assignment you will see that you have "Use Address Pool" checked. You should also check "Use Address from Authentication Server" This way, since you are authenticating to the "Internal" server it will use the address that you have specified for the client in the concentrator. If there is no address there for the client then it will use the pool.
