ACS Initial configuration
Mar 30th, 2007
I would like to perform the initial configuration on a ACS but during the serial console connection I have always the same message:
Error: Failed to get NIC configuration: rc = [-1] unkwown error
Someone can help me?
Thanks in advance.
Vivek Santuka Fri, 03/30/2007 - 08:59
Please ensure that the NIC 1 is connected to the network and restart the ACS.
If it does not work then you will have to reimage the appliance using the CD provided.
Vivek
Minguccio75 Mon, 04/02/2007 - 01:14
I tried to connect the NIC 1 before restarting the ACS but... it doesn't works!
I have no CD because my ACS is a device only for test.
Do you have other ideas?
Vivek Santuka Mon, 04/02/2007 - 06:19
You need need to open a TAC case. They will make the CD's download available to you.
Vivek
Minguccio75 Tue, 04/03/2007 - 02:45
I recivied today the CD to make the restore of the appliance and now all works fine.
