cat4948 sharing of mac addresses
Mar 30th, 2007
How can we use the last 4 ports (RJ45) and the SFP ports at the same time as the MAC address is shared bettween an RJ45 port and a SFP port?
What about:
RJ45 ports without STP for a server/host
SPF ports as trunk beetween switches
glen.grant Fri, 03/30/2007 - 04:13
  • Purple, 4500 points or more
I don't think you can do that you have to select which interface in the config you want to use , you cannot use both .
royalblues Fri, 03/30/2007 - 04:40
  • Green, 3000 points or more
Glenn is right, you cannot use both at the same time.
Its actually 1000baseTx or SFP but not both
Narayan
jabouaf Sun, 04/01/2007 - 23:29
thank you to both of you, but what about using those ports as layer2 ports (not having an ip adresse on both the 2 parts of the couple (RJ45, SFP) ).
for 1 RJ45 port, there is 1 SPF port.
For STP, (if I do not make a mistake), the MAC address is the same for all the switch, even with RSTP)
What do you think about this ?
