1841 ISR series
Answered Question
Mar 30th, 2007
Dear All,
I have few queries about VPN module in 1841 ISR :
a. whether there is On-Board AIM installed in 1841 ?
b. Why we install external(daughter card) AIM-VPN/EPII plus module ?
Are there any serparate commands to enable on board AIM & AIm-VPN/EPII PLUS module ?
regds,
aman
Correct Answer by Amit Singh about 9 years 10 months ago
Hello Aman,
I have found out a DMVPN test results document for you, which will give an idea about the router performances using on-board VPN and AIM VPN module:
http://www.cisco.com/application/pdf/en/us/guest/netsol/ns171/c649/ccmigration_09186a0080739fd3.pdf
HTH,
-amit singh
Correct Answer by Paolo Bevilacqua about 9 years 10 months ago
The native VPN module in all ISR routers is soldered to the motherboard, is not an AIM.
You would install additional AIM modules as required by the cyphered throughput (must be a lot).
There are no commands required to use them, it's automatic.
Hope this helps. Please rate all useful posts!
Overall Rating: 3.5 (2 ratings)
Correct Answer
Paolo Bevilacqua Fri, 03/30/2007 - 05:28
amansoi_5 Fri, 03/30/2007 - 05:56
Thanks...
Can I get some document where I can performance related to this?
aman
