active-active Configuration
Mar 30th, 2007
Hi all,
my customer wants to have an active - active configuration with his 2 CSS. To get the whole bandwitdh in our datacenter i want to connect this both with two routers in a crossover fashion. The first router should be the Default Gateway for the first CSS and the second router should be the DG for the second CSS. VRRP on both routers and on borth CSS should be also configured for the redundancy. Anyone to knows problems with this Configurations orsome pitfalls ??
thx for your comments.
bye joerg
joquesada Fri, 03/30/2007 - 23:43
  • Bronze, 100 points or more
Hi Joerg,
If you want full redundancy, it is good to have L2 switches between the CSSs and the routers. This in order to avoid having a single point of failure on the crossover cables between the CSSs and the routers.
Also, don't use the physical interfaces of the routers as the DG of the CSSs, the VRRP address should be the DG of the CSSs. The reason for this is that if you use the physical address as DG, the CSS pointing to this router would lose connectivity if this router fails, so it is better to use the floating IP as DG.
Besides that, I see you have a good picture of what you needs to be done to get this working. Thanks!
Jose.
