Cisco Network Assistant (5.1) Question
Mar 30th, 2007
I've been working with the network assistant application on one computer and have all the communities setup. What files can I or do I need to move from my workstation to my laptop so that I would not have to reset up my communities?
Craig Balfour Mon, 04/02/2007 - 04:40
Cisco Network Assistant stores this data in "c:\Documents and Settings\\.networkassistant".
If you have one or more communities defined you should find a communities sub-directory containing XML files based on your community names.
In theory, if you transfer the communities sub-directory to the new machine you should see all of your communities on the new machine. Alternatively, if Network Assistant needs some of the other data stored in the root of the .networkassistant directory you will need to transfer .networkassistant and all of its sub-directories.
