Formatting Flash Memory
Mar 30th, 2007
Hello All,
I hav Cisco 2621 Router, i just ordered flash memory(32MB FS).
I have installed the flash memory in to the router by removing older one, but as i boot the router router goes in to ROMMON as it dosent has any IOS, now i am trying to download the IOS from ROMMON using "tftpdnld" switch but it says the Flash is not formated.
so How can i format the new FLASH to load any IOS in to that.
Dhaval Tandel
royalblues Fri, 03/30/2007 - 06:53
  • Green, 3000 points or more
Dhaval,
you can use the format flash: command in the Rommon mode to foramt the flash.
check out the following links
http://www.cisco.com/en/US/products/hw/routers/ps341/prod_installation_guide09186a00802a6394.html
http://www.cisco.com/en/US/products/sw/iosswrel/ps1828/products_configuration_guide_chapter09186a00800ca550.html
HTH, rate if it does
Narayan
dhavaltandel Fri, 03/30/2007 - 07:10
Thanks for takin interest,
I dont have format command supported on present ROMMON.
rommon 15 > ?
alias set and display aliases command
boot boot up an external process
break set/show/clear the breakpoint
confreg configuration register utility
cont continue executing a downloaded image
context display the context of a loaded image
cookie display contents of cookie PROM in hex
dev list the device table
dir list files in file system
dis display instruction stream
dnld serial download a program module
frame print out a selected stack frame
help monitor builtin command help
history monitor command history
meminfo main memory information
repeat repeat a monitor command
reset system reset
set display the monitor variables
stack produce a stack trace
sync write monitor environment to NVRAM
sysret print out info from last system return
tftpdnld tftp image download
unalias unset an alias
unset unset a monitor variable
xmodem x/ymodem image download
Dhaval Tandel
royalblues Fri, 03/30/2007 - 07:27
Dhaval,
Can you just try executing the command ?
Narayan
