03-30-2007 06:59 AM - edited 03-14-2019 08:46 PM
we know that an 7912 use 3 licenses. If I purchase 100 x 7912G ip phones, how many licenses LIC-CM-XXX= need I purchase
If I purchase an VG224 gateway , need I purchase aditiona licenses?
03-31-2007 07:50 AM
You will need 300 device license units, so 3 x LIC-CM-DL-100= will do it.
You do not need any additional licenses for VG224 GW.
HTH,
Chris
04-01-2007 08:22 AM
To add to what Chris mentioned above, please refer to this FAQ for future questions on CM5.x licensing model.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_qanda_item0900aecd805009fc.shtml
04-09-2007 06:21 AM
That means if need purchase for example 2 vg248 or vg224 I dont need purchase licences... right?.
04-02-2007 11:34 AM
OK.
if I have the following:
LIC-CM5.1-7825=
LIC-CM-DL-100= (x 3)
Which is the difference between
CP-7912G-CH1
and
CP-7912G=
Which part number need I order to complete
the 300 licenses?.
300 x CP-7912G-CH1
or
100 x CP-7912G=
Where I wrong?..
thanks
04-02-2007 02:41 PM
Hi Rafael,
Just thought that I should let you know that the 7912G has been announced as "End of Sale" "End of Life" see attached.
EoS and EoL for Cisco Unified IP Phone 7912G
http://www.cisco.com/en/US/products/hw/phones/ps379/prod_eol_notice0900aecd80538042.html
You probably want to go with another model like the 7911G, which is the Cisco recommended replacement model.
http://www.cisco.com/en/US/products/ps6565/index.html
As far as ordering/Licensing goes why don't you fire off an email to;
I'm sure they will set this straight.
Hope this helps!
Rob
04-02-2007 04:51 PM
Rafael,
Just like Rob suggested, it would be wise to go for a 7911. Whether you choose to go one or the other, 7912 and 7911, both require only 3 DLUs per phone. So you will need either,
a. LIC-CM-DL-100 * 3
b. CP-7912G * 100
or
a. LIC-CM-DL-100 *3
b. CP-7911G * 100.
Sankar.
