Recover Deleted Configurations
Mar 30th, 2007
I am removing configurations off of old cisco switches. Is there possibly a way to recover a configuration after it has been deleted? Is there a special procedure for cleaning switches so that nobody can recover old data?
mahmoodmkl Fri, 03/30/2007 - 11:42
U can backup ur configuration to the tftp server.after removing the configurations u an still restore them from tftp server.
u can erase u r nvram to permanently delte the configuration.
Mahmood
jason_lacher Fri, 03/30/2007 - 11:46
I don't need to keep the configurations, I want to make sure that nobody else can recover them.
mahmoodmkl Fri, 03/30/2007 - 11:50
Just erase ur nvram and reload the switches.the switch is going to factory default settings.No one will be able to recover it.
Mahmood
jason_lacher Fri, 03/30/2007 - 12:01
Thanks Mahmood.
I was pretty sure that by erasing the file nobody would be able to recover any of the old configurations. I just wanted to make sure.
situwayne Fri, 03/30/2007 - 13:22
If you switch support this command.
"no service password-recovery"
glen.grant Sat, 03/31/2007 - 03:38
I would check flash, bootflash,slot0, disk 0 etc and make sure no one saved any configs in there , if they did then you must delete and squeeze if needed . Write erase will get rid of the current config but a lot of times people will download configs in flash for different reasons .
jasonrandolph Fri, 03/30/2007 - 14:50
Write erase should permanently dump configuration stored in nvram.
If you need to wipe configurations/files that were stored to flash you should use the squeeze command.
squeeze device: (Example, flash:)
