Access-list and route-maps/NAT
Mar 30th, 2007
Good day;
Need some advice if I may ask I'm trying to do a static nat using route maps so I can just add subnets in the future does this look like it will work. I have a BGP connection and I have to NAT my address to his as follows:
ip nat inside source static 192.168.11.19 170.132.237.49 route-map vnet-nat extendable
ip nat inside source static 192.168.11.37 170.132.237.50 route-map vnet-nat extendable
ip nat inside source static 192.168.11.22 170.132.237.51 route-map vnet-nat extendable
ip nat inside source static 192.168.11.40 170.132.237.52 route-map vnet-nat extendable
ip nat inside source static 192.168.11.42 170.132.237.53 route-map vnet-nat extendable
ip nat inside source static 192.168.11.24 170.132.237.54 route-map vnet-nat extendable
ip nat inside source static 192.168.11.20 170.132.237.55 route-map vnet-nat extendable
ip nat inside source static 192.168.10.62 170.132.237.56 route-map vnet-nat extendable
ip access-list extended VNet-in
permit tcp 10.254.26.0 0.0.0.255 192.168.10.0 0.0.0.255
permit tcp 10.254.27.0 0.0.0.255 192.168.11.0 0.0.0.255
p access-list extended VNet-out
permit tcp 192.168.10.0 0.0.0.255 10.254.26.0 0.0.0.255
permit tcp 192.168.11.0 0.0.0.255 10.254.27.0 0.0.0.255
ip access-list extended vnet-nat
permit ip any 170.132.237.48 0.0.0.15
route-map vnet-nat permit 10
match ip address vnet-nat
Thank you in advance
wgranada1 Thu, 04/05/2007 - 10:22
Thank you for the information but I was able to figure it out....I appreciate the info!!!!
