03-30-2007 12:37 PM - edited 03-18-2019 07:09 PM
We keep getting an error message stating that the DN entry is incorrect. We have tried every flavor of cn=xx,o=xx,ou=xx but with no luck. Has anyone else had success with this and if so, could you shine some light on this for me. Any help would be greatly appreciated....
Solved! Go to Solution.
03-31-2007 07:59 AM
I just did an integration of CM 5.1 to AD,
make sure your search base distinguish name starts from the bottom, fo example assume you AD strucutre:
AD Forest - comnpanyX.com
OU - production
CN - users
the the string should be:
CN=users, OU=production, DC=companyX, DC=com
make sure that the ldap authentication user you specifed has access to the LDAP.
Chris
03-31-2007 07:59 AM
OU - production
CN - users
Chris
04-03-2007 03:44 AM
That syntax seemed to the trick, thank you so much for your help!
