03-30-2007 12:40 PM - edited 03-18-2019 07:10 PM
I have a issue with with our Unity. Basicly when I recieve a voice message at the end when it tells what time I recieved the message it is a hour off. I know the DST time changed and the server time does reflect that. But somehow UNITY is still giving the old time. Is ther a update I missed for this?
Dave
03-30-2007 01:11 PM
I have Unity 4.05, Exchange 2003 offbox. Windows 2003 sp1.
We did the following.
Made sure that all the exchange servers and the Unity exchange tools were at sp2.
Applied the windows 2003 sp1 dst patch
Patched the Unity JRE.
Applied all relevent patches to the CCM servers and AD servers also.
rlp
03-30-2007 01:19 PM
Thanks, I did find the patch on Cisco TAC site for Java I think that is the one that is missing.
Again
Dave
04-02-2007 09:09 AM
David,
you need to shut unity down, go into your control panel and set the time zone to any other time zone, close and re-open, set to the correct time zone, restart unity.. then your tui interface will say the correct time.
04-02-2007 11:00 AM
I found that you may need to reboot server after the above changes are made. Its a Unity to Exchange Sync problem. Rebooting seems to correct issue.
