Detailed Regular Expression Examples for Baseline Config LMS 2.5.1
Answered Question
Can someone provide a site, or post here some detailed examples of how to use regular expressions in baseline config? Everything that I have found is lacking in detail and explaination. Specifically I am trying to write an expression that will cover both "no ip domain-lookup" and "no ip domain lookup" Thanks!
Correct Answer by Joe Clarke about 10 years 2 months ago
First, the regexp you need:
[#no ip domain[- ]lookup#]
As for guides, I highly recommend the O'Reilly book, Mastering Regular Expressions. There are also plenty of online references. Since we use the Perl-compatible suite of regular expressions, something like http://www.perl.com/doc/manual/html/pod/perlre.html will be helpful.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Fri, 03/30/2007 - 14:14
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
