03-30-2007 03:59 PM
Hi, I work for a company with few stores in the USA, how can I monitor/restrict the bandwidth of the stores, for instance, I would like to block sites like youtube, hi5, etc, also efectively block MSN, WebMSN, and yahoo Messenger, and block all peer-to-peer downloads (kazaa, emule, limewire, etc etc)
My network scenario in each store is: INTERNET > CISCO > SWITCH'S > PC-USERS
thanks in advance!
Aldo
03-30-2007 06:56 PM
I would like to setup the netgear FWAG114 as a firewall with disabled routing, that is because the neatgear FWAG114 is behind a cisco router, and I dont want the "cisco integrated services router" to be replaced by the netgear, I only would like to use the firewall capabilities of the netgear. Is there a way for achieve it?
thanks in advance.
Aldo
03-31-2007 12:56 PM
my goal is to block, MSN messenger, youtube, and peer-2-peer clients,
my cisco have a c870-advsecurityk9-mz.123-8.YI2 IOS, I think i can block ports with the cisco ACL but cant block msn and cant block by url, thats for I mind to combine with the netgear... just a think...
04-04-2007 01:23 PM
Hi, I contacted the Netgear support and they told me that my Netgear appliance have disabled the routing by default, so i just changed the subnet and attached to the my cisco router, that way I got a gateway between my router and my network with url filtering capabilities. Now I have the next question derived of the action I performed...
* In the cisco device I have configured Site to Site VPN with another remote identical cisco, I have a large ACL (access contro lists), i have NAT (port forwards for many virtual servers and many services...), and if now I have the Netgear to have a different subnet, it must became the DHCP server(I think) and default gateway for the network, is that right? If yes, the cisco NAT, ACL, VPN will become useless due a different subnet... is that a way to have the Netgear as a firewall but network clients having the cisco as a default gateway having the network to have the cisco subnet instead of the netgear-firewall subnet keeping all the cisco features as well as the netgear features... or May the cisco device handle with the Middle Netgear appliance and is there a way to keep all both devices features?
Cisco --> Netgear --> Network
Thanks in advance again.
Aldo
04-23-2007 12:11 AM
Your Cisco 870 series image should be able to do the job of a firewall, for the ease of use, Cisco provided the SDM,Security device manager. called it up by using https://routeripaddress. from there you can self explorer.
04-23-2007 10:55 AM
So, do you recommend me to do all the job with the cisco or add a new device to the network?
