Firewall broadcasting
Mar 30th, 2007
guys,
i have configured a new 525 Firwall into my network recently, but something starnge happend to the internal network.
i noticed slowing down the entire network some times some of my application not responding and getting dissconneting (even the pinging inside the same network oscillate ).
does the firewall generate such aproblem (broadcasting) ??
i've attached the config
thanks in advance,
hasan
abinjola Fri, 03/30/2007 - 16:44
Firstly you are running an obsolete code on the new FW (6.2.2)
Secondly does sh int shows up any error on interface ?....also what are the instantatenous values for sh conn count..sh xlate count (when the issue occurs)?
hassan_oudeh Fri, 03/30/2007 - 17:38
First of all Thanks for your response, the following are the sh int,sh xlate count and sh connection count
pixfirewall# sh int
interface ethernet0 "outside" is up, line protocol is up
Hardware is i82559 ethernet, address is 0011.2026.6f0e
IP address XX.XX.XX.130, subnet mask 255.255.255.240
MTU 1500 bytes, BW 10000 Kbit half duplex
2560677 packets input, 1870286438 bytes, 0 no buffer
Received 214445 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
1956691 packets output, 399125631 bytes, 0 underruns
0 output errors, 932 collisions, 0 interface resets
0 babbles, 0 late collisions, 4453 deferred
0 lost carrier, 0 no carrier
input queue (curr/max blocks): hardware (128/128) software (0/3)
output queue (curr/max blocks): hardware (0/51) software (0/51)
interface ethernet1 "inside1" is up, line protocol is up
Hardware is i82559 ethernet, address is 0011.2026.6f0f
IP address 192.168.0.253, subnet mask 255.255.255.0
MTU 1500 bytes, BW 100000 Kbit full duplex
2795251 packets input, 469386042 bytes, 0 no buffer
Received 315948 broadcasts, 0 runts, 0 giants
3066074 packets output, 2706764097 bytes, 0 underruns
0 output errors, 827 collisions, 0 interface resets
0 babbles, 0 late collisions, 2780 deferred
979 lost carrier, 0 no carrier
input queue (curr/max blocks): hardware (128/128) software (0/20)
output queue (curr/max blocks): hardware (2/31) software (0/18)
pixfirewall# sh conn count
19 in use, 235 most used
pixfirewall# sh xlate count
10 in use, 349 most used
pixfirewall#
