EasyVPN client and internet/local lan access
Mar 30th, 2007
I connect to my remote network (Pix501) using EasyVPN with a shared key. I have checked the allow local lan access selection on the transport tab but cannot access the internet through my local lan/router. Any suggestions?
amritpatek Thu, 04/05/2007 - 11:26
  • Silver, 250 points or more
Allowing Local Lan Access would no prevent the internet access.Check for the normal internet troubleshooting fetures such as router configuration.Also check if the NATing is done fine on the router
barryhill Fri, 04/06/2007 - 14:03
Sorry. I didn't explain myself well enough. I am working from home and using EasyVPN to establish a VPN tunnel through our Pix501 at work to access our work network. I want to concurrently use the internet. What set up is required to do that?
barryhill Fri, 04/13/2007 - 14:55
Split tunnel and ACL has been configured. The problem is that the local computer makes the IP address assigned to the VPN connection (DHCP assigned by the PIX) as the default gateway in the route table.
