CVP Survivability.tcl Script
Mar 30th, 2007
From what I have read in the CVP Config and Admin guide, it looks to me like the survivability.tcl script should have the ability to recover a call and forward it to an alternate destination in the event of a failure. I have implemented it as close as I could to the documentation but calls are still completely disconnected when I stop the PG or the combo box during a call.
Has anyone else out there had better luck? The script works for all subsequent calls, but any active calls are always dropped. Any help would be greatly appreciated.
nkleven Sat, 03/31/2007 - 10:05
Here you go Andrew, I am sure I butchered this. For sake of this discussion, my CVP dialed number is 5000, running in comprehensive mode. I have attached a "Show Run" and "Show Ver". You will notice I have several dial-peers at the end of the dialplan that I have been using to test. Basically the best I have come up with is when I dial 5001 the tcl scripts tries the CVP script first and then it routes to a secondary number.
What I really need is for the script to take the call in the event of a PG or combo box failure and transfer to the number listed. Is this possible? Let me know if you have any questions. I really appreciate your help!
Nate
