needs H323 configuration example
Mar 30th, 2007
hi all,
i have 2811 voice gateway with only 2 vic2-4fxo ports.
please can any one provide me with H323 configuration example that matches my case with a brief discription because i didn't configure H323 gateway before.
so please help
thanx in advance
a.gooding Fri, 03/30/2007 - 21:28
  • Bronze, 100 points or more
BASIC RUN DOWN
1. configure dial-peers on router
example, if you have an fxo port say 1/0/0
and you want all calls to go through that
then
dial-peer voice 1 pot
destination-pattern .T
port 1/0/0
then for incoming calls to reach an extension create and VOIP dial-peer sending it to the ip of your CCM.
3. create an h323 gateway under device/gateway config. specify the IP of the rtr. it will always come up with unknown but with the ip registered. Make sure your CSS is correct.
4. create a route-pattern to whatever number you desire to pass through the FXO and under select gateway/hunt-list select the gateway.(Note to select specific ports first you need to use the preference command in the dial-peer)
basically, thats it however, there are a few other configs to ensure that voice takes the correct path. bind to the interface you want voice to pass,remove VAD if you hear "voice cuts on the line" allow rtp send-receve if you experience one-way audio(could be several other factors as well that may cause this).
and i think thats about that. im sure you will get some othe more specfic responses from the forum
wahab101 Mon, 04/09/2007 - 18:59
What is missing from this answer is the two h323-gateway lines un der one of the interfaces you need to choose to attach the h323-gateway to it as follows;
for example if you choose the loopback interface
you will have to have
h323-gateway voice interfcae enabled under this one and also the h323-gateway bind line is also enabled under it . Also you will have to use this interface ip add on the call manager when you configure the gateway in the device -- gateway -- h323-gateway type.
johnnylingo Mon, 04/09/2007 - 09:37
Here's a basic example from a 2600 with ISDN PRI. Should be enough to get you started.
ip cef
isdn switch-type primary-ni
voice service voip
h323
no h225 timeout keepalive
session transport udp
voice class codec 711
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class h323 10
h225 timeout tcp establish 3
controller T1 0/0
framing esf
linecode b8zs
pri-group timeslots 1-24
interface FastEthernet0/0
ip address 192.168.1.31 255.255.255.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip id MyGateway ipaddr 192.168.1.31
interface Serial0/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
dial-peer voice 4001 voip
description First CallManager
preference 1
incoming called-number ....
destination-pattern ^....$
voice-class codec 711
voice-class h323 10
session target ipv4:1.2.3.4
dtmf-relay h245-alphanumeric
dial-peer voice 4002 voip
description Second CallManager
preference 2
voice-class h323 10
session target ipv4:5.6.7.8
dial-peer voice 4003 voip
description Tertiary CallManager
preference 3
voice-class h323 10
session target ipv4:1.2.8.9
dial-peer voice 1 pots
description PSTN
destination-pattern 9.T
direct-inward-dial
port 0/0:23
gatekeeper
shutdown
