877W - Lost SDM access
Mar 30th, 2007
My new 877W router was configured by a technitian using command line interface. As a consequence I have now lost the use of the SDM program that came with the router.
The error message says that http/https access must have been disabled.
Not being too familiar with IOS commands I am not even able to change the original username and password (which warries me greatly).
Can any advise how I can get the use of the SDM program back on this router? Will greatly appreciate any help
RP
ahmet-saat Sat, 03/31/2007 - 08:50
hi,
Here what you can do,
1- Get a connection to router console
You can use following link how can you do this,
http://www.cisco.com/warp/public/63/terminal_settings.html
2- Router> ena
This will get you to privilidge mode. If it asks for a password enter password.
3- Router# conf t
This will get you to Configuration mode
4- Router(config)# ip http server
5- Router(config)# ip http secure-server
These commands will enable HTTP and HTTPS
6- Router(config)# end
7- Router# copy run start
You can find more information about SDM by clicking the following link
http://www.cisco.com/en/US/products/sw/secursw/ps5318/index.html
RatanPrakash Sat, 03/31/2007 - 16:04
Thanks for your suggestion. It still doesn't work. It appears there are some discrepencies in ip settings in the configurstion.
Here is a copy of the config settings. For obvious reasons I have removed or blocked out the security info.
Any ideas what is wrong with this config?
Current configuration : 4847 bytes
version 12.4
no service pad
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
resource policy
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp pool sdm-pool
import all
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
lease 0 2
no ip domain lookup
ip domain name yourdomain.com
crypto pki trustpoint
username cisco privilege 15 secret xxx
username <******> privilege 15 secret 5 <***********************>.
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 0/100
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 10.55.210.254 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
interface Dialer1
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname <*******>
ppp chap password 0 <*******>
ppp pap sent-username <*******> password 0 <********>
ip classless
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
ip http access-class 23
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source static tcp 10.55.210.10 443 interface Dialer1 443
ip nat inside source static tcp 10.55.210.10 25 interface Dialer1 25
ip nat inside source static tcp 10.55.210.10 80 interface Dialer1 80
access-list 1 permit 10.55.210.0 0.0.0.255
access-list 23 permit 10.10.10.0 0.0.0.7
no cdp run
control-plane
banner login ^C
Cisco Router and Security Device Manager (SDM) is installed on this device.
This feature requires the one-time use of the username "cisco"
with the password "cisco". The default username and password have a privilege le
vel of 15.
Please change these publicly known initial credentials using SDM or the IOS CLI
Here are the Cisco IOS commands.
username privilege 15 secret 0
no username cisco
Replace and with the username and password you want to use
For more information about SDM please follow the instructions in the QUICK START
GUIDE for your router or go to http://www.cisco.com/go/sdm
^C
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
password cisco
login
transport input telnet ssh
scheduler max-task-time 5000
end
