spanning tree
Mar 31st, 2007
with spanning tree, do all switches use the fastest way back to the root and block any other paths ?
glen.grant Sat, 03/31/2007 - 06:58
It will pick the lowest cost route back to the root and will block any paths that have loops in them . If your design has no built in loops no ports will be blocked .
carl_townshend Sat, 03/31/2007 - 07:31
If I have 2 distribution switches, each switch plugs into both of them, and 1 dist switch is the root, i gather all switches will have a direct connection to the root, and the other link that goes to the other dist switch will be blocked, is this right ?
joyride_us Sun, 04/01/2007 - 23:52
Hi Carl,
not quite that way though (some friends of mine have had bad surprises there!)! Only the BridgeID decides which switch will be the root bridge. You can manipulate this by changing the switch priority (which is one of the components of the BridgeID).
Rule of thumb : STP is a delicate subject : it is worth re-reading your favorite STP book from A to Z before any manipulation!
