should i config a gateway on AP?
Mar 31st, 2007
I have 6 autonomous AP1121, and all connect to a 3560 PoE switch with a DHCP and IAS RADIUS server on network, so should i configure the gateway for those APs?
scottmac Sat, 03/31/2007 - 07:32
It won't affect the operation as an AP at all either way.
The Default Gateway is just there so you can access the APs remotely for administration (through a router).
Without the DG, you'd only be able to access the administrative front-end from the LAN/VLAN/Broadcast Domain that the AP is attached to.
Good Luck
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
