dBWalker Subscriber Count
Mar 31st, 2007
Unity 4.2.1. Replacement install Voicemail only with Exhcange 2003 off box.
dBwalker reports 1046 local subacribers but 1047 in the directory. How can I determine who's missing?
lindborg Sun, 04/01/2007 - 17:26
This just means there's an entry in the GlobalSubscriber table for someone not homed on the local box - likely this is something like an Example Administrator from a previous install that's "floating". You can open the Global Subscriber table in CUDLE or Enterprise Manager and sort the table by the LocationOBjectID - all of them will be associated with the same location (i.e. the location of the local box) but one guy.
