Per-VRF Traffic Engineering
mel_bs
Could anyone show how to configure a Per-vrf traffic engineering in MPLS Backbone?
Mel Sebastian
5 Replies 5
Kypamop
Dunno actually if the feature exists in IOS now. If you have a link about this please post it here.
Maybe you should try to play with different Loopback addresses. For instance create two Loopbacks on the tail-end, then setup two TE-tunnels from head-end. Be sure to advertise VRFs with different next-hop (pointing to Lo1 and Lo2 accordingly) via MP-BGP. But i'm not sure that there's no "hidden obstacles" with this scenario.
Harold Ritter
Mel,
One way to do it is
- Setup a tunnel (no autoroute announce) on the ingress PE
- configure a static route through that tunnel interface as follow:
ip route x.x.x.x 255.255.255.255 tu0
- And use this same address as the bgp next-hop on the egress PE using the following command:
ip vrf xxx
bgp next-hop loxx
This way only the traffic destined to this address will traverse this specific tunnel.
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
I have plotted below a similar configuration to my customer setup for the per-vrf TE which you suggest.
PE2 is a central vrf and has extranet to customer 1 and 3 vrf?s. Since there will be a defined bgp nex-hop on the cust_1 vrf pointing to PE2, and while central vrf will also have bgp next-hop pointing to PE1, what will happen to the PE2 central vrf going to PE3 cust_3 vrf traffic?
PE1 :
ip vrf cust_1
rd 1:1
route-target export 1:1
route-target import 1:1
bgp next-hop Loopback1
interface Loopback1
description NEXT_HOP VRF cust_1
ip address 192.168.1.211 255.255.255.255
ip route 192.168.1.221 255.255.255.255 Tunnel1
PE2 :
ip vrf central
rd 1:2
route-target export 1:2
route-target import 1:2
route-target export 1:3
route-target import 1:3
interface Loopback1
ip address 192.168.1.221 255.255.255.255
ip route 192.168.1.211 255.255.255.255 Tunnel1
PE3 :
ip vrf cust_3
rd 1:3
Mel
Traffic from PE2 to PE3 and vice versa will continue to be routed through the LDP signaled LSP and therefore following the IGP route.
Hope this helps,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Thanks for your help and time...
Mel
