FAX - CallMAnager 4.0 Router 2811
Apr 1st, 2007
We are using CallManager 4.1 and router 2811.
We are using the router to get fax using:
dial-peer voice 833 pots
service onramp
incoming called-number XXXXXXX
direct-inward-dial
port 0/0/0:15
dial-peer voice 803 mmoip
service fax_on_vfc_onramp_app out-bound
destination-pattern XXXXXXX
information-type fax
session target mailto:[email protected]
Some time the tif come corrupted.
from the same fax some time it's come with no problem.
any idea?
msolak Sun, 04/01/2007 - 03:04
1. check whether you have slips on your controller.
show controller e1 0/0/0
2.check whether your clock is syncronized.
network-clock-participate wic 0
network-clock-select 1 e1 0/0/0
regards
mehmet
idanlerer Sun, 04/01/2007 - 03:54
Thanks for helping
E1 0/0/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20040802, FPGA: 13, spm_count = 0
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (460 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in Interval 1:
Data in Interval 2:
Data in Interval 3:
Data in Interval 96:
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
I try to rn the command
but error after network-clock-
