Can this scenario be done? ACS with 3rd party devices
Hi all,
I would like to know if this scenario can be accomplished using ACS 4.1? The flow process are as follows:
1. Cisco PSDN accepts wireless users for authentication & passes authentication details to ACS
2. ACS establishes a connection to an external DB2 database using LDAP
3. Once authenticated, IP will be dynamically assigned using the IP Pool
4. At the same time, a customized RADIUS attribute (service_code) and framed-IP attribute to be passed to a 3rd party device for accounting purposes
Oh and the service_code attribute value will be from the DB2 database. This sounds rather complicated and would appreciate if anyone can help. Thanks in advance
Vivek Santuka Mon, 04/02/2007 - 06:24
The only thing which cannot be done in your scenario is the attribute from external DB.
An attribute from ACS can be passed but not from the ext. db.
